Saltar al contenido principal
PlayStation TV Thermal Pad Replacement
Qué necesitas
  1. PlayStation TV Thermal Pad Replacement, Motherboard: paso 1, imagen 1 de 2 PlayStation TV Thermal Pad Replacement, Motherboard: paso 1, imagen 2 de 2
    • Use the plastic spudger to pry up the bottom piece of the case to release the clips.
  2. PlayStation TV Thermal Pad Replacement: paso 2, imagen 1 de 2 PlayStation TV Thermal Pad Replacement: paso 2, imagen 2 de 2
    • Remove the four 6 mm Phillips screws.
    • Remove the two Phillips #0 screws.
  3. PlayStation TV Thermal Pad Replacement: paso 3, imagen 1 de 2 PlayStation TV Thermal Pad Replacement: paso 3, imagen 2 de 2
    • Remove the heat shield using the plastic opening tool.
    • Slide the tool around the edges until the shield is free.
  4. PlayStation TV Thermal Pad Replacement: paso 4, imagen 1 de 2 PlayStation TV Thermal Pad Replacement: paso 4, imagen 2 de 2
    • Remove the last 6mm Phillips #0 screw from the motherboard.
  5. PlayStation TV Thermal Pad Replacement: paso 5, imagen 1 de 2 PlayStation TV Thermal Pad Replacement: paso 5, imagen 2 de 2
    • Use a plastic opening tool to pry up gently on the motherboard, and remove it.
  6. PlayStation TV Thermal Pad Replacement, Thermal Pad: paso 6, imagen 1 de 2 PlayStation TV Thermal Pad Replacement, Thermal Pad: paso 6, imagen 2 de 2
    • Remove the old thermal pad with an ESD safe tool, like a Jimmy.
  7. PlayStation TV Thermal Pad Replacement: paso 7, imagen 1 de 2 PlayStation TV Thermal Pad Replacement: paso 7, imagen 2 de 2
    • Wipe down the area where the old thermal pads were located with rubbing alcohol.
    • It is important that the area be as clean as possible.
Conclusión
3 personas más completaron esta guía.
Theodore Hesse
Miembro Desde 01/22/16
145 Reputación
1 Guía escrita
Equipo
IUPUI, Team 3-1, Baechle Spring 2016 Miembro de IUPUI, Team 3-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G1
4 Miembros
4 Guías creadas
2 comentarios
Photos for steps 6 through 9 will be posted soon!
Luk Davis - Contestar
Do you replace the thermal pad? Your directions do not state where to do this, and if so what part and size do you recommend?
Daimonion - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 29
Todo El Tiempo: 1,774
