Saltar al contenido principal
Introducción
This will guide you through the replacement of your Power Supply.
Partes
No se especificaron partes.
  1. Remove the parallel port cover on the back of the PlayStation.
    • Remove the parallel port cover on the back of the PlayStation.
  2. Flip over the PlayStation and remove the six screws from the bottom.
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  4. Turn the PlayStation upright. Remove the cover by lifting it up.
    • Turn the PlayStation upright. Remove the cover by lifting it up.
  5. Remove the two screws securing the power supply to the console.
    • Remove the two screws securing the power supply to the console.
  6. Detach the connector from the power supply.
    • Detach the connector from the power supply.
  7. Lift up the left side of the power supply. Slide it to the left to remove it.
    • Lift up the left side of the power supply. Slide it to the left to remove it.
Conclusión
16 personas más completaron esta guía.
JakeDeschamps
Miembro Desde 28/10/09
1,053 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-2, Regan Fall 2009 Miembro de Cal Poly, Team 5-2, Regan Fall 2009
CPSU-REGAN-F09S5G2
5 Miembros
14 Guías creadas
Since working with the power supply, it's wise to state in writing to disconnect the AC cord, in addition to showing it disconnected as you have.
Collin - Contestar
Once I take out my power supply how do I fix the issue with the power supply
Tiago - Contestar
im done removing the power supply so whats next???btw i accidentally plugged my ps1 110v to 220v how to fix that issue???
kendofox - Contestar
Before anything unplug your PlayStation and try the power button couple a times to turn on the PlayStation.
Just check the fuse with a multimeter. It is a cylindrical tube with metal on it’s two corners. The easy way is to check continuity with a mutimeter which is a symbol with a speaker on it. Touch red and black probes and you will hear a beep. Connect the two ends of the fuse and if it beeps then fuse is ok. You can even check it while fuse is on the board. If ok and PlayStation is not working then there is a problem somewhere else on the power board, mostly…
Good Luck!!
gUru0026 -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 12
Últimos 30 Días: 76
Todo El Tiempo: 18,918
