Introducción
This will guide you in replacing the Mother board of a PlayStation One.
Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
  1. Remove all cables plugged into the PlayStation.
    • Remove all cables plugged into the PlayStation.
  2. Flip over the PlayStation and remove the six screws from the bottom. Flip over the PlayStation and remove the six screws from the bottom.
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. Flip the PlayStation back.
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  5. Lift up and remove the upper case. Lift up and remove the upper case.
    • Lift up and remove the upper case.
  6. Disconnect the ribbon cable and wired cable connectors. Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy. Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy.
    • Disconnect the ribbon cable and wired cable connectors.
    • Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy.
  7. remove the metal plate remove the metal plate
    • remove the metal plate
  8. remove the mother board by lifting the back. if you're having a hard time removing it, use your nail and lift the second controller port. if you're having a hard time removing it, use your nail and lift the second controller port.
    • remove the mother board by lifting the back.
    • if you're having a hard time removing it, use your nail and lift the second controller port.
Conclusión
12 personas más completaron esta guía.
trickster
Miembro Desde 23/12/13
1,914 Reputación
11 Guías creadas
I think that the GPU in my PS One is going bad (screen flickers green and pink on occasion but it is becoming more frequent). Would replacing the motherboard fix this? That is, is the GPU stored on the motherboard?
Eric Rosenberg - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 9
Últimos 30 Días: 53
Todo El Tiempo: 4,898
