Saltar al contenido principal
PlayStation One Lower Case Replacement
Qué necesitas
  1. PlayStation One Lower Case Replacement, Upper Case: paso 1, imagen 1 de 1
    • Remove all cables plugged into the PlayStation.
  2. PlayStation One Lower Case Replacement: paso 2, imagen 1 de 2 PlayStation One Lower Case Replacement: paso 2, imagen 2 de 2
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. PlayStation One Lower Case Replacement: paso 3, imagen 1 de 1
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. PlayStation One Lower Case Replacement: paso 4, imagen 1 de 2 PlayStation One Lower Case Replacement: paso 4, imagen 2 de 2
    • Lift up and remove the upper case.
  5. PlayStation One Lower Case Replacement, Laser Assembly: paso 5, imagen 1 de 3 PlayStation One Lower Case Replacement, Laser Assembly: paso 5, imagen 2 de 3 PlayStation One Lower Case Replacement, Laser Assembly: paso 5, imagen 3 de 3
    • Disconnect the cables from the PSone’s board.
    • Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
  6. PlayStation One Lower Case Replacement, Mother Board: paso 6, imagen 1 de 2 PlayStation One Lower Case Replacement, Mother Board: paso 6, imagen 2 de 2
    • remove the metal plate
  7. PlayStation One Lower Case Replacement: paso 7, imagen 1 de 3 PlayStation One Lower Case Replacement: paso 7, imagen 2 de 3 PlayStation One Lower Case Replacement: paso 7, imagen 3 de 3
    • remove the mother board by lifting the back.
    • if you're having a hard time removing it, use your nail and lift the second controller port.
  8. PlayStation One Lower Case Replacement, Lower Case: paso 8, imagen 1 de 2 PlayStation One Lower Case Replacement, Lower Case: paso 8, imagen 2 de 2
    • Remove the metal case.
Conclusión
5 personas más completaron esta guía.
Marjorie
Miembro Desde 12/23/13
2,273 Reputación
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 51
Todo El Tiempo: 4,028
