Saltar al contenido principal
Herramientas
No se especificaron herramientas.
Partes
No se especificaron partes.
  1. Remove all cables plugged into the PlayStation.
    • Remove all cables plugged into the PlayStation.
  2. Flip over the PlayStation and remove the six screws from the bottom. Flip over the PlayStation and remove the six screws from the bottom.
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. Flip the PlayStation back.
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Lift up and remove the upper case. Lift up and remove the upper case.
    • Lift up and remove the upper case.
  6. Disconnect the ribbon cable and wired cable connectors. Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy. Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy.
    • Disconnect the ribbon cable and wired cable connectors.
    • Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy.
  7. remove the metal plate remove the metal plate
    • remove the metal plate
  8. remove the mother board by lifting the back. if you're having a hard time removing it, use your nail and lift the second controller port. if you're having a hard time removing it, use your nail and lift the second controller port.
    • remove the mother board by lifting the back.
    • if you're having a hard time removing it, use your nail and lift the second controller port.
  9. Remove the metal case. Remove the metal case.
    • Remove the metal case.
Conclusión
3 personas más completaron esta guía.
trickster
Miembro Desde 23/12/13
1,941 Reputación
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 17
Todo El Tiempo: 1,629
