Introducción
The rumble motor is the device that allows the move controller to vibrate. This guide will help you replace it if it is broken or damaged.
Herramientas
Partes
No se especificaron partes.
Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
Using a soldering iron, carefully desolder the wires from the board. For help with desoldering, please check out this guide: How To Solder and Desolder Connections
Un Comentario
Step 7, there are 2 screws at the top near the white spherical piece holding the PCB on place that also need to be removed before you can lift it out
