Saltar al contenido principal
PlayStation Move Rumble Motor Replacement
Qué necesitas
  1. PlayStation Move Rumble Motor Replacement, Case: paso 1, imagen 1 de 2 PlayStation Move Rumble Motor Replacement, Case: paso 1, imagen 2 de 2
    • Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
  2. PlayStation Move Rumble Motor Replacement: paso 2, imagen 1 de 3 PlayStation Move Rumble Motor Replacement: paso 2, imagen 2 de 3 PlayStation Move Rumble Motor Replacement: paso 2, imagen 3 de 3
    • Pinch the sides of the back panel to remove it and set it aside.
  3. PlayStation Move Rumble Motor Replacement: paso 3, imagen 1 de 2 PlayStation Move Rumble Motor Replacement: paso 3, imagen 2 de 2
    • Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it.
  4. PlayStation Move Rumble Motor Replacement: paso 4, imagen 1 de 2 PlayStation Move Rumble Motor Replacement: paso 4, imagen 2 de 2
    • Push the Lithium Ion battery from its slot to remove it.
    • Be mindful not to damage the wires or wired components, as the battery will still be attached via its connector.
  5. PlayStation Move Rumble Motor Replacement: paso 5, imagen 1 de 1
    • Unscrew the 9mm screw in the battery slot with a PH #00 screwdriver.
  6. PlayStation Move Rumble Motor Replacement: paso 6, imagen 1 de 2 PlayStation Move Rumble Motor Replacement: paso 6, imagen 2 de 2
    • Using a plastic opening tool, carefully pry the rumble motor free.
  7. PlayStation Move Rumble Motor Replacement: paso 7, imagen 1 de 1
    • Unscrew the 9mm screw behind the rumble motor slot with a PH #00 screwdriver.
  8. PlayStation Move Rumble Motor Replacement: paso 8, imagen 1 de 3 PlayStation Move Rumble Motor Replacement: paso 8, imagen 2 de 3 PlayStation Move Rumble Motor Replacement: paso 8, imagen 3 de 3
    • Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller.
  9. PlayStation Move Rumble Motor Replacement: paso 9, imagen 1 de 2 PlayStation Move Rumble Motor Replacement: paso 9, imagen 2 de 2
    • Using your fingers, carefully pry the square green piece beneath the battery slot free.
    • It is attached via white ribbons which need to be kept intact.
  10. PlayStation Move Rumble Motor Replacement: paso 10, imagen 1 de 3 PlayStation Move Rumble Motor Replacement: paso 10, imagen 2 de 3 PlayStation Move Rumble Motor Replacement: paso 10, imagen 3 de 3
    • Follow the white ribbon attached to the part you just removed to a smaller, more rectangular piece.
    • Lift the rectangular piece from its slot to free it.
  11. PlayStation Move Rumble Motor Replacement: paso 11, imagen 1 de 3 PlayStation Move Rumble Motor Replacement: paso 11, imagen 2 de 3 PlayStation Move Rumble Motor Replacement: paso 11, imagen 3 de 3
    • Carefully lift the entire circuit board from the black plastic encasing it.
    • Take extra care not to damage any of the wired components.
  12. PlayStation Move Rumble Motor Replacement, Rumble Motor: paso 12, imagen 1 de 1
    • Using a soldering iron, carefully desolder the wires from the board. For help with desoldering, please check out this guide: How To Solder and Desolder Connections
    • In order to install the new rumble motor, you must solder the wires of the new motor to the circuit board.
Conclusión
Sarah Shand
Miembro Desde 02/20/17
1,912 Reputación
7 Guías creadas
Equipo
USF Tampa, Team S3-G1, Sullivan Spring 2017 Miembro de USF Tampa, Team S3-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G1
3 Miembros
13 Guías creadas
Un comentario
Step 7, there are 2 screws at the top near the white spherical piece holding the PCB on place that also need to be removed before you can lift it out
Steve Massart - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 18
Ultimos 30 días: 31
Todo El Tiempo: 1,516
