Introducción
This guide will show you how to replace the thermal paste inside a PS4. Now you might wonder just what thermal paste is. Thermal paste is a silver liquid you apply to a processor to transfer heat to a cooling solution. You want to replace the thermal paste of any electronic every couple of years or so since the thermal paste will dry out. The thermal paste board is right under the heat sync, and the heat sync is where all the dust builds up. If you clean the heat sync and replace the thermal paste, your PS4 will be working as if it was brand new. My PS4 is about six years old, and after doing this whole procedure, it never overheats anymore and is as quiet as a mouse. The only skills required for this task is you have to be able to screw and unscrew screws. It is a very easy, but it is a tedious process, so pick a day that you are free if you are going to do this.
Herramientas
Grip the PS4 with both hands along the gap in the top cover.
Push the glossy side of the top cover with your thumbs until it pops to the side.
Lift the glossy top cover up and back to remove it from the PS4.
Remove the 6.5 mm Phillips screw securing the hard drive bracket to the enclosure.
Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
Remove the four 7.2 mm Torx security screws on the back of the PS4.
Remove three 9.7 mm Torx security screws.
Remove two 41 mm Phillips screws and brackets.
Use the tip of a spudger to disconnect the antenna cable from the motherboard.
Use your fingernail to press down on the metal release lever of the ribbon cable on top of the optical drive.
Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab.
Remove the four screws securing the optical drive.
Three 9.7 mm Torx screws
One 6.2 mm Phillips screw
Remove the twelve 9.7 mm Torx screws securing the upper EMI shield.
Insert the flat end of a spudger in between the fan cable and the motherboard.
Twist the spudger to lift the connector straight up and disconnect it from the motherboard.
Using a tissue paper, wipe off the existing thermal paste. Take your new thermal paste and apply a small amount in the middle of the component.
12 personas más completaron esta guía.
Un Comentario
Se me hizo muy buena la guia, sobre todo para no cometer algun error al trabajar en la reparacion, mi PS4 dejo de zumbar el abanico con el cambio de pasta termica y una limpieza general de polvo y pelusa.
