Saltar al contenido principal
Introducción
Consoles such as the PlayStation 4 over time start to overheat from all the excessive dust accumulating. It causes the thermal paste to thin out and the speed drastically reduces. The overheating produces noise and users no longer want the console because of this and some are even willing to replace it. This guide will show people how to clean their PlayStation 4 Slim, replace the thermal paste, and restore the console to fantastic working condition!
  1. Remove the panel next to the ports by sliding it to the right. Use a T9 Torx security screwdriver to remove the screw.
    • Remove the panel next to the ports by sliding it to the right.
    • Use a T9 Torx security screwdriver to remove the screw.
  2. Pull the black ribbon on the side of the PS4 to remove the hard drive.
    • Pull the black ribbon on the side of the PS4 to remove the hard drive.
  3. Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Peel off the plastic warranty sticker next to the three ports on the side of the console.
  4. Flip the PS4 with the bottom side facing upwards and the side of the screw you just removed facing you. Remove the cover by prying the two corners and then sliding it back.
    • Flip the PS4 with the bottom side facing upwards and the side of the screw you just removed facing you.
    • Remove the cover by prying the two corners and then sliding it back.
    • This step will require some force and you will hear clicking sounds as the cover is coming off.
  5. Use a Phillips #0 screwdriver to remove the screw.
    • Use a Phillips #0 screwdriver to remove the screw.
  6. Remove the cover by prying the two corners and then sliding it back. This step will require some force and you will hear clicking sounds as the cover is coming off. Remove the three T9 Torx security screws.
    • Remove the three T9 Torx security screws.
    • Use a Phillips #0 screwdriver to remove the two screws.
    • Lift and remove the metal panel after unscrewing.
  7. Remove the power supply completely by disconnecting the wire.
    • Remove the power supply completely by disconnecting the wire.
  8. Flip the PS4 to view the metal paneling. Lift the black clip on the largest connection to remove it. Disconnect the wire by pulling it back with a little bit of force.
    • Flip the PS4 to view the metal paneling.
    • Lift the black clip on the largest connection to remove it.
    • Disconnect the wire by pulling it back with a little bit of force.
    • By pulling on the blue tabs gently you are able to remove the connections.
    • Gently lift the black wire to disconnect from the motherboard.
  9. Use a Phillips #0 screwdriver to remove all screws. After unscrewing, remove the metal panel to access the motherboard.
    • Use a Phillips #0 screwdriver to remove all screws.
    • After unscrewing, remove the metal panel to access the motherboard.
    • Removing the metal panel may require some force but do not pull up too hard as you may have missed a screw.
  10. Use a Phillips #0 screwdriver to remove two screws. Unplug the wire by pulling firmly.
    • Use a Phillips #0 screwdriver to remove two screws.
    • Unplug the wire by pulling firmly.
    • Lift the metal brace with your fingers to expose the motherboard.
  11. Apply 2-3 droplets of thermal material remover on Q-tips to remove the old thermal paste and then wipe it down with a micro fiber cloth until no residue of old paste is left. Apply 2-3 droplets of thermal surface purifier on a new Q-tip and go over the area cleaned.
    • Apply 2-3 droplets of thermal material remover on Q-tips to remove the old thermal paste and then wipe it down with a micro fiber cloth until no residue of old paste is left.
    • Apply 2-3 droplets of thermal surface purifier on a new Q-tip and go over the area cleaned.
    • Both steps may require multiple repetitions.
  12. Squeeze about 3/4 of an inch of Arctic Silver 5 thermal paste onto the prepared surface. Let the thermal paste rest for 10 minutes before reassembly.
    • Squeeze about 3/4 of an inch of Arctic Silver 5 thermal paste onto the prepared surface.
    • Let the thermal paste rest for 10 minutes before reassembly.
  13. Use a Phillips #0 screwdriver to remove the two screws.
  14. Flip the console. Use a Phillips #0 screwdriver to remove the screw.
    • Flip the console.
  15. Lift up the metal panel and on the back the radiator is located. Clean the radiator by using a brush and a compressed air can.
    • Lift up the metal panel and on the back the radiator is located.
    • Clean the radiator by using a brush and a compressed air can.
  16. Use a Phillips #0 screwdriver to remove the two screws. Clean the fan by using a brush and a compressed air can.
    • Clean the fan by using a brush and a compressed air can.
Conclusión
12 personas más completaron esta guía.
2 comentarios
Hey, can I use this for a original “fat” ps4?
thanks
notle159 - Contestar
Any advice on a good way to clean the fan blades? Thanks for all the other tips!
Nicholas Pratt III - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 34
Ultimos 7 días: 259
Ultimos 30 días: 1,332
Todo El Tiempo: 17,493
