Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Use this guide to remove or replace your Playstation 4 Slim’s power supply.
  1. Locate the plastic warranty sticker next to the three ports on the side of the console. Remove the warranty sticker by peeling it off with any kind of spudger. Removing the warranty sticker will NOT cause your warranty to be null and void.
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
  2. Unscrew and remove the 5.0mm screw that was behind the sticker using a T8 security Torx screwdriver with a counter-clockwise motion. Unscrew and remove the 5.0mm screw that was behind the sticker using a T8 security Torx screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 5.0mm screw that was behind the sticker using a T8 security Torx screwdriver with a counter-clockwise motion.
  3. Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you. Pry up on the two corners that are facing you with your fingers. This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
  4. Place the Playstation 4 Slim right side up,  with the PS logo on top and the side with the words "SONY" and "PS4" facing you. Pry up on the two corners that are facing you with your fingers. This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
    • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Remove the top cover by sliding it towards the back corners and lifting up.
  5. Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion. Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion. Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  6. Remove the four 16mm Philips screws holding the power supply in place.
    • Remove the four 16mm Philips screws holding the power supply in place.
  7. Remove the metal sheet from the top of  the power supply by grabbing and lifting up with your hands. Remove the metal sheet from the top of  the power supply by grabbing and lifting up with your hands.
    • Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
  8. Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel. Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
    • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
  9. Flip the Playstation 4 Slim onto its back. Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Flip the Playstation 4 Slim onto its back.
    • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  10. Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two. Lift the power supply up and onto its back on the metal sheet using your hands. Lift the power supply up and onto its back on the metal sheet using your hands.
    • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
    • Lift the power supply up and onto its back on the metal sheet using your hands.
  11. Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out. Remove the power supply completely by grabbing and lifting up with your hands. Remove the power supply completely by grabbing and lifting up with your hands.
    • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
    • Remove the power supply completely by grabbing and lifting up with your hands.
Conclusión
53 personas más completaron esta guía.
Hernan Rodriguez
Miembro Desde 24/01/18
2,329 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S19-G4, Livingston Winter 2018 Miembro de Cal Poly, Team S19-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G4
4 Miembros
26 Guías creadas
Can the N15-160P1A power supply work on a PS4 system that originally came with N17-160P1A?
derasky4u - Contestar
My PS4 not turning on
Khai Stering - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 43
Ultimos 7 días: 301
Ultimos 30 días: 1,278
Todo El Tiempo: 41,747
