Introducción
Use this guide to remove or replace your Playstation 4 Slim’s disc drive.
Note: If your replacement disc drive did not come with flex cables, you will have to transfer the cables from your original drive.
Qué necesitas
Locate the plastic warranty sticker next to the three ports on the side of the console.
Remove the warranty sticker by peeling it off with any kind of spudger.
Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
Pry up on the two corners that are facing you with your fingers.
Remove the top cover by sliding it towards the back corners and lifting up.
Unscrew and remove the 31.0mm screw using a T8 screwdriver with a counter-clockwise motion.
Unscrew and remove the 10x 5.0mm screws using a Phillips #1 screwdriver with a counter-clockwise motion.
90 personas más completaron esta guía.
24 comentarios
incomplete guide, what replacement? the last step is taking the cover off but what about the disk drive?
Yeah, where's the ending to this?
To remove the complete drive you have to remove the motherboard. with the motherboard removed some of the above steps may not be necessary.
This guide is useful if you just need to remove disc or clean laser.
when replacing do you have to swap a board like the PS4’s of the past?
Nope, on the ps4 slim the optical drive is not married to the motherboard so any drive as long is the same model will work with any motherboard
