Saltar al contenido principal
PlayStation 4 Slim Bottom Cover Replacement
Qué necesitas
  1. PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: paso 1, imagen 1 de 3 PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: paso 1, imagen 2 de 3 PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
  2. PlayStation 4 Slim Bottom Cover Replacement: paso 2, imagen 1 de 2 PlayStation 4 Slim Bottom Cover Replacement: paso 2, imagen 2 de 2
    • Unscrew and remove the now exposed 5.0mm screw using a T8 security Torx screwdriver with a counter-clockwise motion.
  3. PlayStation 4 Slim Bottom Cover Replacement: paso 3, imagen 1 de 3 PlayStation 4 Slim Bottom Cover Replacement: paso 3, imagen 2 de 3 PlayStation 4 Slim Bottom Cover Replacement: paso 3, imagen 3 de 3
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
Conclusión
36 personas más completaron esta guía.
Hernan Rodriguez
Miembro Desde 01/24/18
3,642 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S19-G4, Livingston Winter 2018 Miembro de Cal Poly, Team S19-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G4
4 Miembros
35 Guías creadas
2 comentarios
Wo kann man die Bodenplatte kaufen?
Emre Kaman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 28
Ultimos 7 días: 154
Ultimos 30 días: 780
Todo El Tiempo: 47,538
