Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Archivada
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Archivada
Introducción
The official guide has been updated and can be found here. This guide is archived for historical purposes.
This step-by-step procedure will allow the reader to get to and replace the optical drive responsible for reading the disc. Be aware that any replacement or teardown beyond the hard drive voids the Sony warranty.
Resumen del Video
  1. Disconnect the ribbon wire from the optical drive by pressing down on the metal release tab and gently pulling the ribbon wire. This should not require force.
    • Disconnect the ribbon wire from the optical drive by pressing down on the metal release tab and gently pulling the ribbon wire. This should not require force.
  2. Disconnect the same ribbon wire from the motherboard; making sure you're pressing down on the metal release tab and gently pulling the ribbon wire.
    • Disconnect the same ribbon wire from the motherboard; making sure you're pressing down on the metal release tab and gently pulling the ribbon wire.
  3. Remove the wifi antenna cable attached to the motherboard.
    • Remove the wifi antenna cable attached to the motherboard.
  4. El kit de herramientas esencial
    Las herramientas más útiles en nuestro kit más compacto.
    Compra ahora
    Compra ahora
  5. Remove the optical drive four wire plug from the motherboard by pulling straight out.
    • Remove the optical drive four wire plug from the motherboard by pulling straight out.
  6. Remove the four 9mm Torx T9 screw attached to the wifi antenna and optical drive.
    • Remove the four 9mm Torx T9 screw attached to the wifi antenna and optical drive.
    • Remove the 5mm Phillips head #1 screw.
  7. Lift up and remove the wifi antenna.
    • Lift up and remove the wifi antenna.
  8. The optical drive assembly can now be lifted straight up and removed from the system. Do not discard the daughter board. Be aware that the optical drive is "married" to the motherboard. If you need to replace your optical drive you must remove the daughter board on the original optical drive assembly and install it on the drive you intend to install in your PS4.
    • The optical drive assembly can now be lifted straight up and removed from the system. Do not discard the daughter board.
    • Be aware that the optical drive is "married" to the motherboard. If you need to replace your optical drive you must remove the daughter board on the original optical drive assembly and install it on the drive you intend to install in your PS4.
Conclusión
Robert Harvey
Miembro Desde 01/04/14
9,661 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 8-12, Regan Spring 2014 Miembro de Cal Poly, Team 8-12, Regan Spring 2014
CPSU-REGAN-S14S8G12
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 16
