Saltar al contenido principal
PlayStation 3 Slim Top Cover Replacement
Qué necesitas
  1. PlayStation 3 Slim Top Cover Replacement, Top Cover: paso 1, imagen 1 de 1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim Top Cover Replacement: paso 2, imagen 1 de 2 PlayStation 3 Slim Top Cover Replacement: paso 2, imagen 2 de 2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim Top Cover Replacement: paso 3, imagen 1 de 1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim Top Cover Replacement: paso 4, imagen 1 de 1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim Top Cover Replacement: paso 5, imagen 1 de 2 PlayStation 3 Slim Top Cover Replacement: paso 5, imagen 2 de 2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
Conclusión
92 personas más completaron esta guía.
2 comentarios
No good mine a Sony.
james register - Contestar
Thank you this helped me so much!!!!
Megan Davis - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 94
Ultimos 30 días: 392
Todo El Tiempo: 73,478
