Introducción
PlayStation 3 - How to replace Laser Lens and Mechanism (Laser Deck).
Please SUBSCRIBE to my channel ツ
More info about disassembling, you can find in
PlayStation 3 Slim Teardown
Resumen del Video
  1. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
    • Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
  2. Remove Power Supply. Remove Power Supply. Remove Power Supply.
    • Remove Power Supply.
  3. Separate cables, unscrew the screw and remove the Blu Ray drive. Separate cables, unscrew the screw and remove the Blu Ray drive. Separate cables, unscrew the screw and remove the Blu Ray drive.
    • Separate cables, unscrew the screw and remove the Blu Ray drive.
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  5. Disassemble the upper metal shield. . Please SUBSCRIBE to my channel  ツ
  6. Remove the two very small phillips screws in each lower corner referenced by the red circles. Remove the two very small phillips screws in each lower corner referenced by the red circles. Remove the two very small phillips screws in each lower corner referenced by the red circles.
    • Remove the two very small phillips screws in each lower corner referenced by the red circles.
  7. Be careful with flex cables. Be careful with flex cables. Be careful with flex cables.
    • Be careful with flex cables.
  8. Now you can remove the Laser Deck. Now you can remove the Laser Deck. Now you can remove the Laser Deck.
    • Now you can remove the Laser Deck.
  9. Transfer two flex cables and 2x rubbers. Transfer two flex cables and 2x rubbers. Transfer two flex cables and 2x rubbers.
    • Transfer two flex cables and 2x rubbers.
  10. You can test the console before full assembling. . Did you do it successfully?
Conclusión
12 personas más completaron esta guía.
ZFix
Miembro Desde 09/12/13
162,554 Reputación
304 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
280 Miembros
784 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 90
Últimos 30 Días: 225
Todo El Tiempo: 16,104
