Saltar al contenido principal
PlayStation 3 Slim (CECH-300X) Fan system Replacement
Qué necesitas
Resumen del Video
  1. PlayStation 3 Slim (CECH-300X) Fan system Replacement, Fan system: paso 1, imagen 1 de 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement, Fan system: paso 1, imagen 2 de 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement, Fan system: paso 1, imagen 3 de 3
    • Disconnect the fan cable and remove the nine screws from the bottom side.
  2. PlayStation 3 Slim (CECH-300X) Fan system Replacement: paso 2, imagen 1 de 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: paso 2, imagen 2 de 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: paso 2, imagen 3 de 3
    • Remove the two heat sink clamps and bottom shield, then gently separate the motherboard off the top shield.
  3. PlayStation 3 Slim (CECH-300X) Fan system Replacement: paso 3, imagen 1 de 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: paso 3, imagen 2 de 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: paso 3, imagen 3 de 3
    • Remove the four Phillips screws and lift the top shield.
  4. PlayStation 3 Slim (CECH-300X) Fan system Replacement: paso 4, imagen 1 de 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: paso 4, imagen 2 de 3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: paso 4, imagen 3 de 3
    • That's all.
Conclusión
10 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,368 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,468 Guías creadas
2 comentarios
Awesome guide. Thank you so much. I did it, but now I just wonder what that white stuff was when I removed the motherboard. I think it's that thermal stuff people have been talking about and I suppose I have to replace that. I also hope that it's the fan that is what's causing my PS3 to say that it's overheating and shut off. I'm so glad you guys posted this. Great job. I rather do it myself than pay Sony an arm and a leg. Cheers!
chetacheez - Contestar
This is CPU / GPU thermal paste / compound. I recommend you Arctic MX-2, MX-4. It is very good and not expensive.
ZFix -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 44
Ultimos 30 días: 235
Todo El Tiempo: 16,585
