Introducción
Use this guide to replace your PlayStation 3's proprietary PRAM battery.
Partes
Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
Remove the following seven screws:
Six 52 mm Phillips screws
One 30 mm Phillips screw
Lift the top cover from its rear edge and rotate it toward the front of the PS3.
Remove the top cover.
There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit front the rear of the machine with a spudger to release the rear right of the casing.
Pull the control board ribbon cable straight up and out of its socket on the motherboard.
13 personas más completaron esta guía.
5 comentarios
Ok…tell me why the !&&* the PRAM battery doesnt last in these %#*@ ps3's…they should have to replace this $@$* for free. My ps3 is lucky if it has 60 hours on it…I made sure it didn't go more than 2 months without playing it. Now I have to pay Sony to fix this $@$*. I'm !#^&@@ cause I paid $500 for this %#*@ thing when it came out. If anyone knows anything I don't…please email me at tadheath95@gmail.com put in the subject…..”about ur broken ps3’. Thank you in advance!!!
Hey Tad the ps3 was made 9 years ago a cmos battery lasts 8-10.
The PS3 is over ten years old, way past the average life span of a lithium battery (up to 10 years). Maybe a tad shortsighted of them to embed it so deeply into the console but at least they put it somewhere that decreases the chances of damage if it leaks. That’s worlds apart from the original Xbox where they used capacitors that failed and trashed the motherboard. Xbox 360 I believe doesn’t even have the facility to retain the date/time and had far more serious issues.
This guide didn’t work for my PS3 (fat). I dismantled the PS3 up to the motherboard, and found the PRAM battery there, directly on the motherboard itself, no connector attached. The video https://www.youtube.com/watch?v=yn1OqCw-... was a huge help in combination with this guide.
the ribbon cable for bluray drive is hard to get back in
