Saltar al contenido principal
PlayStation 3 Motherboard Assembly Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. PlayStation 3 Motherboard Assembly Replacement, Motherboard Assembly: paso 1, imagen 1 de 1
    • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
  2. PlayStation 3 Motherboard Assembly Replacement: paso 2, imagen 1 de 2 PlayStation 3 Motherboard Assembly Replacement: paso 2, imagen 2 de 2
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
    • Remove the control board and its attached cable from the PS3.
  3. PlayStation 3 Motherboard Assembly Replacement: paso 3, imagen 1 de 1
    • Remove the following eight screws securing the motherboard assembly to the lower case:
    • Seven 12 mm Phillips screws (ph2)
    • One 30 mm Phillips screw
  4. PlayStation 3 Motherboard Assembly Replacement: paso 4, imagen 1 de 1
    • Remove the control board bracket.
  5. PlayStation 3 Motherboard Assembly Replacement: paso 5, imagen 1 de 2 PlayStation 3 Motherboard Assembly Replacement: paso 5, imagen 2 de 2
    • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
    • Remove the hard drive bay cover.
  6. PlayStation 3 Motherboard Assembly Replacement: paso 6, imagen 1 de 1
    • Lift the motherboard assembly out of the lower case.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,197
