Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
Use this guide to replace your PlayStation 3's black plastic lower case.
  1. Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3. The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3. Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3. Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. Remove the following seven screws:
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit front the rear of the machine with a spudger to release the rear right of the casing.
  7. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  8. Disconnect the Blu-ray power cable from the motherboard.
    • Disconnect the Blu-ray power cable from the motherboard.
    • Pull the connector straight up and out of its socket.
  9. Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
    • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
  10. Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket. Be sure you are prying up on the retaining flap, not the socket itself. Pull the ribbon cable out of its socket.
    • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the Blu-ray drive from the PS3.
    • If replacing the Blu-ray drive, transfer the power cable to your new drive.
  11. Pull the control board ribbon cable straight up and out of its socket on the motherboard.
    • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
  12. Remove the two 12 mm Phillips screws securing the control board to the lower case. Remove the control board and its attached cable from the PS3.
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
    • Remove the control board and its attached cable from the PS3.
  13. Remove the following eight screws securing the motherboard assembly to the lower case:
    • Remove the following eight screws securing the motherboard assembly to the lower case:
    • Seven 12 mm Phillips screws (ph2)
  14. Remove the control board bracket.
    • Remove the control board bracket.
  15. Use the flat end of a spudger to pry the hard drive bay cover away from the lower case. Remove the hard drive bay cover.
    • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
    • Remove the hard drive bay cover.
  16. Lift the motherboard assembly out of the lower case.
    • Lift the motherboard assembly out of the lower case.
  17. Lower case remains.
    • Lower case remains.
Conclusión
9 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 19
Ultimos 30 días: 70
Todo El Tiempo: 15,026
