Saltar al contenido principal
PlayStation 2 Top Cover Replacement
Qué necesitas
  1. PlayStation 2 Top Cover Replacement, Top Cover: paso 1, imagen 1 de 3 PlayStation 2 Top Cover Replacement, Top Cover: paso 1, imagen 2 de 3 PlayStation 2 Top Cover Replacement, Top Cover: paso 1, imagen 3 de 3
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
  2. PlayStation 2 Top Cover Replacement: paso 2, imagen 1 de 1
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
  3. PlayStation 2 Top Cover Replacement: paso 3, imagen 1 de 1
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. PlayStation 2 Top Cover Replacement: paso 4, imagen 1 de 2 PlayStation 2 Top Cover Replacement: paso 4, imagen 2 de 2
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
Conclusión
29 personas más completaron esta guía.
jwyoung
Miembro Desde 11/04/09
2,596 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 19-1, Maness Fall 2009 Miembro de Cal Poly, Team 19-1, Maness Fall 2009
CPSU-MANESS-F09S19G1
4 Miembros
34 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 43
Ultimos 30 días: 180
Todo El Tiempo: 16,399
