Introducción
This guide will walk you through step-by-step on how to properly remove and install the metal chassis in the PlayStation 2 Slimline.
Qué necesitas
Paso 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
Aviso: los pasos 1-7 provienen de una guía que está marcada como "En progreso".
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
Paso 8 IR Sensor
Aviso: el paso 8 proviene de una guía que está marcada como "En progreso".
Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
Locate the fan component of the motherboard of the PS2.
With your fingers or tweezers, peel off the sticker that holds down the fan's wiring.
Paso 14 Optical Drive
Aviso: los pasos 14-18 provienen de una guía que está marcada como "En progreso".
Locate the optical drive on the motherboard.
Locate the metal plate that is attached to the back of the motherboard.
2 personas más completaron esta guía.
