1. Remove screw covers, two are rubber feet, and the six screws located on the bottom of the console. Caution with the "Do not void" seal, underneath is also a screw Caution with the "Do not void" seal, underneath is also a screw
    • Remove screw covers, two are rubber feet, and the six screws located on the bottom of the console.
    • Caution with the "Do not void" seal, underneath is also a screw
  2. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. If all screws are removed. Use a metal spunger to open the chassis
    • If all screws are removed.
    • Use a metal spunger to open the chassis
  4. Slip the three cables out of the sockets. Use a PH01 screwdriver to remove the four screws securing the optical drive Lift up the optical drive and remove the duct tape under the flex cable.
    • Slip the three cables out of the sockets.
    • Use a PH01 screwdriver to remove the four screws securing the optical drive
    • Lift up the optical drive and remove the duct tape under the flex cable.
    • Now the optical drive is free and ready for replacement
Conclusión
11 personas más completaron esta guía.
tlroesner
Miembro Desde 13/05/12
1,788 Reputación
4 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 30
Últimos 30 Días: 123
Todo El Tiempo: 15,578
