Qué necesitas
Desconecta todos los cables de la consola y dale la vuelta para ver la parte de abajo.
Localiza la unidad óptica la cual ocupa la mayoría del espacio en la parte derecha de la unidad. Se puede identificar gracias a los cuatro tornillos de cabeza ancha que fijan la unidad óptica a la placa base.
Para volver a montar tu PlayStation 2 Slimline, sigue esta guía en orden inverso, desde el final hacia el principio.
24 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
7 comentarios
انا أريد للغة عربية
you also must disconnect the ribbon cable from the laser assembly by flipping back the little brown lever and removing the cable. This frees the assembly from the rest of the console. To actually replace the drive, you need to move the lens away from the disc hub by gently turning the worm gear. Flip the new assembly over and connect the brown ribbon that is glued to the metal shield. DO NOT REMOVE THE GLUED RIBBON UNLESS YOU INTEND TO REPLACE IT. After that one is connected, you can slowly flip the assembly and rest is in place. Connect the other ribbons to their respective connectors. Return all the screws to their positions and tighten so they are firm. Don’t go overboard screwing them back in.
Hello is the optical drive from my ps2 70004 compatible in my ps2 slim 75001?
I don't see any reason why it shouldn't be.
This is a great instructional aside from one thing, if you don’t not have the tape/glue for the ribbon cable that goes under the assembly, do not remove that ribbon cable from the shell. just disconnect it from the assembly, and put it in the new assembly. I wish I had read the comments before I did this myself. Please add this to the notes for the instructional. Now one of my games are ruined, and I have to buy a new one.
