Saltar al contenido principal
PlayStation 2 Slimline IR Sensor Replacement
Qué necesitas
  1. PlayStation 2 Slimline IR Sensor Replacement, Outer Shell: paso 1, imagen 1 de 1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline IR Sensor Replacement: paso 2, imagen 1 de 3 PlayStation 2 Slimline IR Sensor Replacement: paso 2, imagen 2 de 3 PlayStation 2 Slimline IR Sensor Replacement: paso 2, imagen 3 de 3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline IR Sensor Replacement: paso 3, imagen 1 de 3 PlayStation 2 Slimline IR Sensor Replacement: paso 3, imagen 2 de 3 PlayStation 2 Slimline IR Sensor Replacement: paso 3, imagen 3 de 3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline IR Sensor Replacement: paso 4, imagen 1 de 3 PlayStation 2 Slimline IR Sensor Replacement: paso 4, imagen 2 de 3 PlayStation 2 Slimline IR Sensor Replacement: paso 4, imagen 3 de 3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline IR Sensor Replacement, IR Sensor: paso 5, imagen 1 de 1
    • Locate the IR sensor at the front, right corner of the unit.
  6. PlayStation 2 Slimline IR Sensor Replacement: paso 6, imagen 1 de 1
    • Gently detach the ribbon cable connecting the IR sensor to the motherboard.
    • Caution: Always remove ribbon cables by the plastic handles located on either end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  7. PlayStation 2 Slimline IR Sensor Replacement: paso 7, imagen 1 de 1
    • Gently lift and remove the IR Sensor from its designated slot.
Conclusión
8 personas más completaron esta guía.
Thomas Sullivan
Miembro Desde 10/23/13
3,927 Reputación
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 96
Todo El Tiempo: 6,830
