Saltar al contenido principal
PlayStation 2 Slimline CMOS Battery Replacement
Qué necesitas
  1. PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: paso 1, imagen 1 de 3 PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: paso 1, imagen 2 de 3 PlayStation 2 Slimline CMOS Battery Replacement, CMOS Battery: paso 1, imagen 3 de 3
    • Remove all five screws on the downside of the PS2 Slimline
    • Remove the "Do not void" seal carefully, underneath is the fifth screw located.
  2. PlayStation 2 Slimline CMOS Battery Replacement: paso 2, imagen 1 de 2 PlayStation 2 Slimline CMOS Battery Replacement: paso 2, imagen 2 de 2
    • Take a metal spudger and open the chassis
  3. PlayStation 2 Slimline CMOS Battery Replacement: paso 3, imagen 1 de 3 PlayStation 2 Slimline CMOS Battery Replacement: paso 3, imagen 2 de 3 PlayStation 2 Slimline CMOS Battery Replacement: paso 3, imagen 3 de 3
    • Locate the battery on the motherboard
    • Use a metal spudger to pull it up
    • Pull the cable and the battery is removed, ready to replace
Conclusión
5 personas más completaron esta guía.
tlroesner
Miembro Desde 05/13/12
1,864 Reputación
4 Guías creadas
3 comentarios
why would i need to do this?
Dimitrios Frantzis - Contestar
To prior poster, you will not be able to effectively play certain types of games once the server is shut off by Sony.
Joe W. - Contestar
What do I replace the battery with? Can I re-apply the rubber casing of the original battery onto a new 2032 or what?
Jarad Webb - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 12
Ultimos 30 días: 43
Todo El Tiempo: 10,906
