Saltar al contenido principal
Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement
Qué necesitas
  1. Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement, Overview: paso 1, imagen 1 de 2 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement, Overview: paso 1, imagen 2 de 2
    • This guide is only to replace the Stick button
  2. Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: paso 2, imagen 1 de 3 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: paso 2, imagen 2 de 3 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: paso 2, imagen 3 de 3
    • Open the little holders
    • then carefully lift the metal plate
  3. Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: paso 3, imagen 1 de 3 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: paso 3, imagen 2 de 3 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: paso 3, imagen 3 de 3
    • Take out the small Springs and pry it open . I marked the direction .
  4. Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: paso 4, imagen 1 de 3 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: paso 4, imagen 2 de 3 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: paso 4, imagen 3 de 3
    • Lift up this metal holder, don´t bend it.
    • Then with tweezers detach the white plastic. It holds the Analog cap.
    • One end of the white plastic is magnetic. Do not damage it
  5. Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: paso 5, imagen 1 de 2 Play Station Vita PSV 1000 Analog Thumb Stick Cap (Thumbstick Button) Replacement: paso 5, imagen 2 de 2
    • Turn the cap and replace it with a new one.
    • * If Sony did not did this thing with the Analog Cap turning we could simply pull out the Cap and place a new one.
    • Assembly is simple like the disassembly :D
Conclusión
Una persona más ha completado esta guía.
cakone micke
Miembro Desde 04/22/19
241 Reputación
1 Guía escrita
Un comentario
Marked as easy? Does it look harder than it is? Looks like it requires alot of precision
Shebaz Raza - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 36
Ultimos 30 días: 177
Todo El Tiempo: 3,864
