Saltar al contenido principal
Plantronics Voyager Legend Earpiece Replacement
Qué necesitas
  1. Plantronics Voyager Legend Earpiece Replacement, Earpiece: paso 1, imagen 1 de 3 Plantronics Voyager Legend Earpiece Replacement, Earpiece: paso 1, imagen 2 de 3 Plantronics Voyager Legend Earpiece Replacement, Earpiece: paso 1, imagen 3 de 3
    • Remove the soft, plastic earpiece.
    • Depress the soft, plastic earpiece. While depressed, rotate the earpiece counterclockwise ninety degrees.
    • List the soft, plastic earpiece out of its position.
  2. Plantronics Voyager Legend Earpiece Replacement: paso 2, imagen 1 de 1
    • Heat the earpiece assembly with a heat gun (a hair dryer will work if a heat gun is not available).
    • The heating softens the adhesive that holds the assembly together, and the assembly may need to be reheated to complete the dis-assembly process.
  3. Plantronics Voyager Legend Earpiece Replacement: paso 3, imagen 1 de 2 Plantronics Voyager Legend Earpiece Replacement: paso 3, imagen 2 de 2
    • The two snaps that combine with the adhesive to hold the assembly together are located in the neck of the earpiece unit.
  4. Plantronics Voyager Legend Earpiece Replacement: paso 4, imagen 1 de 2 Plantronics Voyager Legend Earpiece Replacement: paso 4, imagen 2 de 2
    • Remove the top half of the earpiece assembly.
    • Use the pointed end of a small, metal Spudger to loosen the two tabs that hold the earpiece assembly together.
    • While glue is soft and snaps are loosened, remove the entire top half of the earpiece housing.
  5. Plantronics Voyager Legend Earpiece Replacement: paso 5, imagen 1 de 3 Plantronics Voyager Legend Earpiece Replacement: paso 5, imagen 2 de 3 Plantronics Voyager Legend Earpiece Replacement: paso 5, imagen 3 de 3
    • Remove the speaker housing.
    • With the copper backing plate displayed, use the pointed end of a small, metal Spudger to disassemble the speaker housing.
    • Using the pointed end of the small, metal Spudger, lift the copper, backing plate away from the speaker unit.
  6. Plantronics Voyager Legend Earpiece Replacement: paso 6, imagen 1 de 2 Plantronics Voyager Legend Earpiece Replacement: paso 6, imagen 2 de 2
    • Use Precision Tweezers to remove the protective screen from the front of the speaker unit.
  7. Plantronics Voyager Legend Earpiece Replacement: paso 7, imagen 1 de 3 Plantronics Voyager Legend Earpiece Replacement: paso 7, imagen 2 de 3 Plantronics Voyager Legend Earpiece Replacement: paso 7, imagen 3 de 3
    • Remove the speaker unit and solder a new unit in place.
    • When disconnecting leads, always disconnect as near as possible to the component being replaced, to allow room for reattachment.
    • Locate the leads that connect to the back of the speaker unit.
    • Disconnect the leads from the back of the speaker unit.
    • Remove the speaker unit, and replace by soldering the leads back into their correct locations.
    • Refer to the iFixit soldering guide for assistance with soldering.
Conclusión
7 personas más completaron esta guía.
Lewis Certain
Miembro Desde 09/10/15
2,187 Reputación
3 Guías creadas
Equipo
Un comentario
Thank you for the Guide.
One further Question is open for me: How do you replace the broken rubber near the earpiece?
albert einstein - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 114
Todo El Tiempo: 14,805
