Saltar al contenido principal
Plantronics CS50 Headset Battery Replacement
Qué necesitas
  1. Plantronics CS50 Headset Battery Replacement, Battery: paso 1, imagen 1 de 3 Plantronics CS50 Headset Battery Replacement, Battery: paso 1, imagen 2 de 3 Plantronics CS50 Headset Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Flip the headset face down.
    • Squeeze both sides of the battery cover.
    • While squeezing, pull the cover up slowly to remove it.
  2. Plantronics CS50 Headset Battery Replacement: paso 2, imagen 1 de 3 Plantronics CS50 Headset Battery Replacement: paso 2, imagen 2 de 3 Plantronics CS50 Headset Battery Replacement: paso 2, imagen 3 de 3
    • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
Conclusión
To reassemble your device, follow these instructions in reverse order
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 17-29, Amido Spring 2012 Miembro de Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Miembros
7 Guías creadas
Un comentario
I created the article https://de.ifixit.com/Artikel/Battery_Pl... for a Silvercrest bluetooth transmitter, but I was not able to change the needed parts of this howto to link to that article.
anton2 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 44
Todo El Tiempo: 7,362
