Introducción
This guide will show how to replace the solenoid in the Geo3 if it has become nonfunctional.
Qué necesitas
Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
Using the Phillips #0 screwdriver, remove the 2 screws in the solenoid.
Remove the solenoid.
Casi Terminas!
Conclusión
