Saltar al contenido principal
Planet Eclipse Etha Trigger Replacement
Qué necesitas
  1. Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: paso 1, imagen 1 de 2 Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: paso 1, imagen 2 de 2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  2. Planet Eclipse Etha Trigger Replacement: paso 2, imagen 1 de 1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  3. Planet Eclipse Etha Trigger Replacement: paso 3, imagen 1 de 2 Planet Eclipse Etha Trigger Replacement: paso 3, imagen 2 de 2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  4. Planet Eclipse Etha Trigger Replacement, Trigger: paso 4, imagen 1 de 1
    • Use a hex key to unscrew the middle screw on the top of the trigger.
  5. Planet Eclipse Etha Trigger Replacement: paso 5, imagen 1 de 1
    • Use same hex key to push through trigger retention pin on the side of the gun.
  6. Planet Eclipse Etha Trigger Replacement: paso 6, imagen 1 de 2 Planet Eclipse Etha Trigger Replacement: paso 6, imagen 2 de 2
    • Pull out the trigger by grabbing the bottom and slowly rotating outwards.
Conclusión
Una persona más ha completado esta guía.
Evan Hench
Miembro Desde 10/19/14
211 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-42, Amido Fall 2014 Miembro de Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 8
Todo El Tiempo: 921
