Saltar al contenido principal
Planet Eclipse Etha Eyes Replacement
Qué necesitas
  1. Planet Eclipse Etha Eyes Replacement, Regulator: paso 1, imagen 1 de 2 Planet Eclipse Etha Eyes Replacement, Regulator: paso 1, imagen 2 de 2
    • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
    • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • The macroline is the black hose connecting the regulator to the tank connection.
  2. Planet Eclipse Etha Eyes Replacement: paso 2, imagen 1 de 2 Planet Eclipse Etha Eyes Replacement: paso 2, imagen 2 de 2
    • Remove the regulator by unscrewing it in a clockwise direction.
  3. Planet Eclipse Etha Eyes Replacement, Battery and Grip Panels: paso 3, imagen 1 de 2 Planet Eclipse Etha Eyes Replacement, Battery and Grip Panels: paso 3, imagen 2 de 2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  4. Planet Eclipse Etha Eyes Replacement: paso 4, imagen 1 de 1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  5. Planet Eclipse Etha Eyes Replacement: paso 5, imagen 1 de 2 Planet Eclipse Etha Eyes Replacement: paso 5, imagen 2 de 2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  6. Planet Eclipse Etha Eyes Replacement, Frame: paso 6, imagen 1 de 2 Planet Eclipse Etha Eyes Replacement, Frame: paso 6, imagen 2 de 2
    • Carefully disconnect the three connectors from the circuit board.
    • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
  7. Planet Eclipse Etha Eyes Replacement: paso 7, imagen 1 de 2 Planet Eclipse Etha Eyes Replacement: paso 7, imagen 2 de 2
    • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
  8. Planet Eclipse Etha Eyes Replacement: paso 8, imagen 1 de 1
    • Be very careful during the step to avoid damage to the solenoid or wiring.
    • Gently separate the top and bottom of the marker.
  9. Planet Eclipse Etha Eyes Replacement, Eyes: paso 9, imagen 1 de 2 Planet Eclipse Etha Eyes Replacement, Eyes: paso 9, imagen 2 de 2
    • Use the 5/64" hex key to turn the screw counterclockwise.
    • Carefully remove the screw and place it off to the side.
    • Remove the panel and place it off to the side.
  10. Planet Eclipse Etha Eyes Replacement: paso 10, imagen 1 de 2 Planet Eclipse Etha Eyes Replacement: paso 10, imagen 2 de 2
    • Carefully flip the marker over.
    • Remove the screw and place it off to the side.
    • Carefully remove the panel and place it off to the side.
  11. Planet Eclipse Etha Eyes Replacement: paso 11, imagen 1 de 2 Planet Eclipse Etha Eyes Replacement: paso 11, imagen 2 de 2
    • Grip the marker with one hand and gently pull the eyes out with your other hand.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 10-42, Amido Fall 2014 Miembro de Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 1,206
