Saltar al contenido principal
Planet Eclipse Etha Bolt O-rings Replacement
Qué necesitas
  1. Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: paso 1, imagen 1 de 3 Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: paso 1, imagen 2 de 3 Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: paso 1, imagen 3 de 3
    • Using the 1/4" hex key, turn the bolt counterclockwise and remove.
  2. Planet Eclipse Etha Bolt O-rings Replacement: paso 2, imagen 1 de 2 Planet Eclipse Etha Bolt O-rings Replacement: paso 2, imagen 2 de 2
    • Slide the bolt tip and spring off of the main assembly.
    • Keep a towel handy, you may get some grease on your hands.
  3. Planet Eclipse Etha Bolt O-rings Replacement: paso 3, imagen 1 de 3 Planet Eclipse Etha Bolt O-rings Replacement: paso 3, imagen 2 de 3 Planet Eclipse Etha Bolt O-rings Replacement: paso 3, imagen 3 de 3
    • Unscrew the casing from the rest of the bolt.
    • Again, you may get some grease on your hands during this step.
  4. Planet Eclipse Etha Bolt O-rings Replacement: paso 4, imagen 1 de 3 Planet Eclipse Etha Bolt O-rings Replacement: paso 4, imagen 2 de 3 Planet Eclipse Etha Bolt O-rings Replacement: paso 4, imagen 3 de 3
    • Grab the flat surface shown.
    • Unscrew this portion counter clockwise to remove it.
    • If you're having trouble unscrewing the part, try using a small wrench.
  5. Planet Eclipse Etha Bolt O-rings Replacement: paso 5, imagen 1 de 2 Planet Eclipse Etha Bolt O-rings Replacement: paso 5, imagen 2 de 2
    • Grab the threaded cover and slide it away from the spring.
    • The bolt should now be in three pieces.
    • The threaded cover is the same part that you unscrewed in the last step.
  6. Planet Eclipse Etha Bolt O-rings Replacement: paso 6, imagen 1 de 3 Planet Eclipse Etha Bolt O-rings Replacement: paso 6, imagen 2 de 3 Planet Eclipse Etha Bolt O-rings Replacement: paso 6, imagen 3 de 3
    • Replace and lubricate the 9 marked O-rings.
    • O-ring removal will be explained in the next step.
  7. Planet Eclipse Etha Bolt O-rings Replacement: paso 7, imagen 1 de 3 Planet Eclipse Etha Bolt O-rings Replacement: paso 7, imagen 2 de 3 Planet Eclipse Etha Bolt O-rings Replacement: paso 7, imagen 3 de 3
    • Grab the O-ring on the sides.
    • Pinch the O-ring upwards to create a gap between the metal and the ring.
    • Use a small object to slip into the loop and pull the O-ring off gently.
    • We recommend using a small Allen Key for this.
Conclusión
Una persona más ha completado esta guía.
nicholasj6
Miembro Desde 10/14/14
261 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-42, Amido Fall 2014 Miembro de Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 12
Todo El Tiempo: 2,134
