Saltar al contenido principal
Planet Eclipse Etha Battery and Grip Panels Replacement
Qué necesitas
  1. Planet Eclipse Etha Battery and Grip Panels Replacement, Battery and Grip Panels: paso 1, imagen 1 de 2 Planet Eclipse Etha Battery and Grip Panels Replacement, Battery and Grip Panels: paso 1, imagen 2 de 2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  2. Planet Eclipse Etha Battery and Grip Panels Replacement: paso 2, imagen 1 de 1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  3. Planet Eclipse Etha Battery and Grip Panels Replacement: paso 3, imagen 1 de 2 Planet Eclipse Etha Battery and Grip Panels Replacement: paso 3, imagen 2 de 2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
Conclusión
Una persona más ha completado esta guía.
Jared Olson
Miembro Desde 10/14/14
211 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-42, Amido Fall 2014 Miembro de Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 1,197
