Introducción
If your Pipo Smart S1 Speaker is not working or not producing clear audio (audio is buzzing, fuzzy, or otherwise unclear), this guide will show you how to replace the speaker in your device.
The speaker in your Pipo Smart S1 works by converting electrical signals into sound waves that you can hear. If any part of your speaker is defective, it will result in unclear or no audio.
Before replacing the speaker, turn off the device and disconnect it from any external power sources.
Replacing the speaker in the Pipo Smart S1 requires the use of a soldering iron. Follow this guide for information on how to solder connections.
Qué necesitas
Insert an iFixit opening tool between the body and display of the tablet at the bottom of the device where the charging port is.
Slide the tool along the gap you are creating, moving to the right direction against the mini USB port.
Find the charging port at the bottom of your device.
Insert the spudger into the seam between the front and back panels of the device.
