Saltar al contenido principal
Pioneer MXT-X366BT Metal Case Replacement
Qué necesitas
  1. Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: paso 1, imagen 1 de 2 Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: paso 1, imagen 2 de 2
    • Apply small amount of pressure inward with a plastic opening tool to release bottom clip.
    • Pry the top clip with the plastic opening tool to release it.
    • The head unit is symmetrical and has the same amount of clips on the other side.
  2. Pioneer MXT-X366BT Metal Case Replacement: paso 2, imagen 1 de 1
    • Remove the face plate holder.
  3. Pioneer MXT-X366BT Metal Case Replacement: paso 3, imagen 1 de 1
    • Remove the six 5mm Phillips-head screws with Philips #2 screwdriver.
  4. Pioneer MXT-X366BT Metal Case Replacement: paso 4, imagen 1 de 2 Pioneer MXT-X366BT Metal Case Replacement: paso 4, imagen 2 de 2
    • Remove the inner three 5mm Phillips head screws, with a Phillips #2 screwdriver, attached to the metal backing.
    • Remove the metal backing that is now free.
  5. Pioneer MXT-X366BT Metal Case Replacement: paso 5, imagen 1 de 1
    • Carefully slide the metal casing forward.
    • Metal piece standing is the rear of the head unit.
    • Edges are sharp.
  6. Pioneer MXT-X366BT Metal Case Replacement: paso 6, imagen 1 de 1
    • Lift the metal casing from the rear and pull it away.
    • Edges are sharp.
  7. Pioneer MXT-X366BT Metal Case Replacement: paso 7, imagen 1 de 1
    • The metal casing is now fully removed.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 276
