Introducción
A faulty USB port can cause the user unable to play media to the radio receiver. This guide will show you how to replace the USB port for the Pioneer FH-X730BS.
Qué necesitas
Apply pressure to the tabs on each side using the plastic opening tool.
You will need to pull the face away from the frame while unhooking the tabs.
Here you are able to desolder the USB ports from the circuit board and solder a replacement USB port on.
Casi Terminas!
Conclusión
