Introducción
A faulty USB port can cause the user unable to play media to the radio receiver. This guide will show you how to replace the USB port for the Pioneer FH-X730BS.
  1. Apply pressure to the tabs on each side using the plastic opening tool. You will need to pull the face away from the frame while unhooking the tabs. You will need to pull the face away from the frame while unhooking the tabs.
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. After removing the stereo face from the frame it should look similar to this. Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face. Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
    • After removing the stereo face from the frame it should look similar to this.
    • Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the volume knob by pulling it towards you and pull the motherboard out of the face. The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons. You can now insert the replacement audio buttons into the face.
    • Remove the volume knob by pulling it towards you and pull the motherboard out of the face.
    • The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons.
    • You can now insert the replacement audio buttons into the face.
  5. Here you are able to desolder the USB ports from the circuit board and solder a replacement USB port on.
    • Here you are able to desolder the USB ports from the circuit board and solder a replacement USB port on.
    • The end of the soldering iron will be hot.
Conclusión
Cody Pesta
Miembro Desde 17/09/18
667 Reputación
6 Guías creadas
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 33
