Introducción
A broken disk drive can cause the user unable to play CDs on the radio receiver. This guide will show you how to replace the disk drive for the Pioneer FH-X730BS.
Partes
No se requieren partes.
  1. Apply pressure to the tabs on each side using the plastic opening tool. You will need to pull the face away from the frame while unhooking the tabs. You will need to pull the face away from the frame while unhooking the tabs.
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. After removing the stereo face from the frame, it should look similar to this.
    • After removing the stereo face from the frame, it should look similar to this.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the ribbon wire from where it is being held in place. This can be done by applying force upwards.
    • Remove the ribbon wire from where it is being held in place. This can be done by applying force upwards.
  5. Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame. Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame. Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame.
    • Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame.
  6. Unscrew the four  inner screws that are 7.3 mm long using a Phillips #1 head screw driver to remove the disk drive from the top face plate. Replace the old disk drive with a new one. Replace the old disk drive with a new one.
    • Unscrew the four inner screws that are 7.3 mm long using a Phillips #1 head screw driver to remove the disk drive from the top face plate.
    • Replace the old disk drive with a new one.
Conclusión
Cody Pesta
Miembro Desde 17/09/18
667 Reputación
6 Guías creadas
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 44
