Saltar al contenido principal
Pioneer FH-X730BS Auxiliary Inlet Replacement
Qué necesitas
  1. Pioneer FH-X730BS Auxiliary Inlet Replacement, Deck Buttons: paso 1, imagen 1 de 3 Pioneer FH-X730BS Auxiliary Inlet Replacement, Deck Buttons: paso 1, imagen 2 de 3 Pioneer FH-X730BS Auxiliary Inlet Replacement, Deck Buttons: paso 1, imagen 3 de 3
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. Pioneer FH-X730BS Auxiliary Inlet Replacement: paso 2, imagen 1 de 3 Pioneer FH-X730BS Auxiliary Inlet Replacement: paso 2, imagen 2 de 3 Pioneer FH-X730BS Auxiliary Inlet Replacement: paso 2, imagen 3 de 3
    • After removing the stereo face from the frame it should look similar to this.
    • Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
  3. Pioneer FH-X730BS Auxiliary Inlet Replacement: paso 3, imagen 1 de 3 Pioneer FH-X730BS Auxiliary Inlet Replacement: paso 3, imagen 2 de 3 Pioneer FH-X730BS Auxiliary Inlet Replacement: paso 3, imagen 3 de 3
    • Remove the volume knob by pulling it towards you and pull the motherboard out of the face.
    • The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons.
    • You can now insert the replacement audio buttons into the face.
  4. Pioneer FH-X730BS Auxiliary Inlet Replacement, Auxiliary Inlet: paso 4, imagen 1 de 1
    • Here you are able to desolder the auxiliary ports from the circuit board and solder a replacement auxiliary port on.
    • The end of the soldering iron will be hot.
Conclusión
Cody Pesta
Miembro Desde 09/17/18
688 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 182
