Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide gives steps to replace the motherboard of the speaker. This part may be need to be replaced if the speaker does not turn on or is not responding to commands.
  1. Flip the speaker upside down with the back panel of plugs pointed away from you.
    • Flip the speaker upside down with the back panel of plugs pointed away from you.
  2. Use the metal spudger to pry off the rubber bottom cover.  It will be glued onto the bottom of the speaker. Work the rubber cover off by slowly going all the way around with the metal spudger, applying as much force as needed.
    • Use the metal spudger to pry off the rubber bottom cover. It will be glued onto the bottom of the speaker.
    • Work the rubber cover off by slowly going all the way around with the metal spudger, applying as much force as needed.
    • Since the cover is glued, a heat gun at low temperature or a hair dryer may be useful to speed up the process. However it is not required in this step.
  3. Scrape most of the glue away to reveal the five flathead screws - four around the outside, and one in the middle.
    • Scrape most of the glue away to reveal the five flathead screws - four around the outside, and one in the middle.
  4. Remove the five 6 mm screws with a Phillips #2 screwdriver.
    • Remove the five 6 mm screws with a Phillips #2 screwdriver.
  5. Lift off the metal plate. It will be surprisingly heavy and it is approximately 1cm thick.
    • Lift off the metal plate. It will be surprisingly heavy and it is approximately 1cm thick.
  6. This step requires permanently damaging the casing of your device. Turn the speaker counter-clockwise 90 degrees. Use a knife to cut along the left seam all the way down the length of the device.
    • This step requires permanently damaging the casing of your device.
    • Turn the speaker counter-clockwise 90 degrees.
    • Use a knife to cut along the left seam all the way down the length of the device.
  7. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  8. The casing should be easily removed by prying and lifting it off. If the casing gets caught on the back panel of plugs, use the metal spudger to lift the casing away from the panel, working all the way around. Pay special attention to the bottom, where it may be stuck with glue.
    • The casing should be easily removed by prying and lifting it off.
    • If the casing gets caught on the back panel of plugs, use the metal spudger to lift the casing away from the panel, working all the way around. Pay special attention to the bottom, where it may be stuck with glue.
  9. Flip device 180 degrees so the light ring/button panel is on top with the 'Elite' facing you. Remove one 6 mm screw with a Phillips #2 screwdriver. Spin the device so the opposite side is facing you.
    • Flip device 180 degrees so the light ring/button panel is on top with the 'Elite' facing you.
    • Remove one 6 mm screw with a Phillips #2 screwdriver.
    • Spin the device so the opposite side is facing you.
    • Remove the two 6 mm screws with a Phillips #2 screwdriver.
  10. Carefully remove the top panel, light ring, button panel, and the corresponding board. Do not pull too hard, as there is a strip of wiring connected to the part below that could tear if pulled too hard or too far away.
    • Carefully remove the top panel, light ring, button panel, and the corresponding board.
    • Do not pull too hard, as there is a strip of wiring connected to the part below that could tear if pulled too hard or too far away.
  11. Peel off all rubber strips along sides, middle front and middle back of the device. Peel off all rubber strips along sides, middle front and middle back of the device. Peel off all rubber strips along sides, middle front and middle back of the device.
    • Peel off all rubber strips along sides, middle front and middle back of the device.
  12. Remove the eight 6 mm screws using the Phillips #2 screwdriver.
    • Remove the eight 6 mm screws using the Phillips #2 screwdriver.
  13. Pry apart the two sides carefully. The halves will not be able to separate completely because of wires and the motherboard.
    • Pry apart the two sides carefully. The halves will not be able to separate completely because of wires and the motherboard.
  14. Slide the motherboard out using your hands. Slide the motherboard out using your hands.
    • Slide the motherboard out using your hands.
  15. Slide out ribbon-like wire at the bottom of the speaker using your hands. Slide out ribbon-like wire at the bottom of the speaker using your hands.
    • Slide out ribbon-like wire at the bottom of the speaker using your hands.
  16. Remove two of the wire connectors with your hands or with tweezers.
    • Remove two of the wire connectors with your hands or with tweezers.
  17. Remove the two wire connectors using tweezers or your fingers. Be careful not to damage the plastic. Remove the 3 pieces of hot glue using tweezers. Don't worry about ripping the foam covering the cords. Remove the ribbon wire by pulling on it with tweezers.
    • Remove the two wire connectors using tweezers or your fingers. Be careful not to damage the plastic.
    • Remove the 3 pieces of hot glue using tweezers. Don't worry about ripping the foam covering the cords.
    • Remove the ribbon wire by pulling on it with tweezers.
    • Removing this may permanently damage the connector.
  18. Peel away the off white glue and disconnect the wires from the motherboard.
    • Peel away the off white glue and disconnect the wires from the motherboard.
    • Remove the motherboard from the device.
    • Disconnecting the wires from the motherboard may require desoldering them.
Conclusión
Equipo
Cal Poly, Team S24-G10, Maness Spring 2018 Miembro de Cal Poly, Team S24-G10, Maness Spring 2018
CPSU-MANESS-S18S24G10
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 159
