Introducción
This guide will walk you through replacing the LED light ring and button panel. To completely separate the two from the device, you may need to know how to solder and desolder connections.
Qué necesitas
Flip the speaker upside down with the back panel of plugs pointed away from you.
Lay the speaker down flat to make it easier to work on.
Remove the seven 4 mm screws with a Phillips #2 screwdriver.
Gently pry the plastic light ring from the circuit board and button panel.
