Introducción
Replacing the motherboard of the Pioneer Elite Pro-R06U may be necessary if the receiver is dropped or takes water damage. This part is the trickiest to replace as it is located beneath all other components of the receiver.
Partes
No se requieren partes.
  1. Remove the two 6.4 mm Phillips screws on each side of the device's casing.
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  2. Remove the two 6.5 mm Phillips screws on the back of the device casing.
    • Remove the two 6.5 mm Phillips screws on the back of the device casing.
  3. Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
  4. To replace the back cooling fan, grip the ribbon connector at slot M10 and remove by gently pulling upward.
    • To replace the back cooling fan, grip the ribbon connector at slot M10 and remove by gently pulling upward.
  5. Remove the two 6.5 mm Phillips mounting screws at the back of the device.
    • Remove the two 6.5 mm Phillips mounting screws at the back of the device.
  6. Grip the frame of the cooling fan and slide away from the back wall until the tabs are no longer in the holes of the casing.
    • Grip the frame of the cooling fan and slide away from the back wall until the tabs are no longer in the holes of the casing.
    • Lift the cooling fan out of the device.
  7. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  8. To remove the optical drive cooling fan, grip the ribbon connector at M11 and gently remove by pulling away for the slot.
    • To remove the optical drive cooling fan, grip the ribbon connector at M11 and gently remove by pulling away for the slot.
  9. Flip the latch on the ribbon connector upward to allow for cable removal.
    • Flip the latch on the ribbon connector upward to allow for cable removal.
    • Grip the ribbon cable and remove by gently pulling away from the unlatched connector.
  10. Remove the two 6.4 mm Phillips mounting screws on the optical drive cooling fan.
    • Remove the two 6.4 mm Phillips mounting screws on the optical drive cooling fan.
  11. Grip the frame of the cooling fan and slide it toward the front panel, then lift out of the device.
    • Grip the frame of the cooling fan and slide it toward the front panel, then lift out of the device.
  12. Unplug ribbon cables D4 and D5. To unplug D4, flip the gate up and pull the ribbon away.
    • Unplug ribbon cables D4 and D5. To unplug D4, flip the gate up and pull the ribbon away.
  13. Remove four 1/4th inch Phillips screws on the back of the casing.
    • Remove four 1/4th inch Phillips screws on the back of the casing.
    • Unscrew and remove the nut from the threaded connector.
  14. The optical drive is still connected by a cable on its bottom side, lift the drive upwards only slightly when first removing from the casing. Pull the optical drive toward the interior of the device and then lift upwards, then pull to remove the cord on the bottom left corner before removing the drive completely.
    • The optical drive is still connected by a cable on its bottom side, lift the drive upwards only slightly when first removing from the casing.
    • Pull the optical drive toward the interior of the device and then lift upwards, then pull to remove the cord on the bottom left corner before removing the drive completely.
  15. Unplug connectors at M1, M4, M7, M8, M9 by gently pulling upward. Remove all 3/8 inch Phillips screws connecting motherboard to casing.
    • Unplug connectors at M1, M4, M7, M8, M9 by gently pulling upward.
    • Remove all 3/8 inch Phillips screws connecting motherboard to casing.
  16. Remove the five 1/4 inch Phillips screws and two 1/8 inch Phillips screws on the back of the casing.
    • Remove the five 1/4 inch Phillips screws and two 1/8 inch Phillips screws on the back of the casing.
    • Unscrew and remove nut from threaded connector.
  17. Remove four 1/2 inch screws using a nutdriver.
    • Remove four 1/2 inch screws using a nutdriver.
  18. Pinch the securing tabs and lift the motherboard toward the interior of the device to remove it.
    • Pinch the securing tabs and lift the motherboard toward the interior of the device to remove it.
  19. Pull it toward the interior of the device and lift it away.
    • Pull it toward the interior of the device and lift it away.
Conclusión
Cody Carter
Miembro Desde 30/01/18
1,049 Reputación
6 Guías creadas
Equipo
Baylor, Team S1-G5, Johnson Spring 2018 Miembro de Baylor, Team S1-G5, Johnson Spring 2018
BU-JOHNSON-S18S1G5
3 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 9
Todo El Tiempo: 152
