Saltar al contenido principal
Pioneer A1 XW-SMA1-K Motherboard Replacement
Qué necesitas
  1. Pioneer A1 XW-SMA1-K Motherboard Replacement, Back Panel: paso 1, imagen 1 de 1
    • Use the spudger to remove the mesh front panel.
  2. Pioneer A1 XW-SMA1-K Motherboard Replacement: paso 2, imagen 1 de 2 Pioneer A1 XW-SMA1-K Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the thirteen 12 mm screws in the speaker frame.
    • Remove the speaker frame by pulling vertically upwards revealing the motherboard.
  3. Pioneer A1 XW-SMA1-K Motherboard Replacement: paso 3, imagen 1 de 3 Pioneer A1 XW-SMA1-K Motherboard Replacement: paso 3, imagen 2 de 3 Pioneer A1 XW-SMA1-K Motherboard Replacement: paso 3, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the twelve 12 mm screws from the middle frame.
    • Remove the middle frame by pulling upward and vertically.
  4. Pioneer A1 XW-SMA1-K Motherboard Replacement: paso 4, imagen 1 de 2 Pioneer A1 XW-SMA1-K Motherboard Replacement: paso 4, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove the nine 12 mm screws from the motherboard.
    • Flip the motherboard over.
    • Remove the motherboard by detaching the antenna.
  5. Pioneer A1 XW-SMA1-K Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Remove the motherboard from the speaker.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 16
Todo El Tiempo: 575
