Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Picture Frame Matting Replacement
Qué necesitas
  1. Picture Frame Matting Replacement, Picture Frame Matting: paso 1, imagen 1 de 1
    • Place the picture frame face down on a clean surface.
  2. Picture Frame Matting Replacement: paso 2, imagen 1 de 1
    • Use a spudger to rotate all of the frame’s backing clips away from the frame.
  3. Picture Frame Matting Replacement: paso 3, imagen 1 de 2 Picture Frame Matting Replacement: paso 3, imagen 2 de 2
    • Remove the backing by lifting it up and away using a spudger.
  4. Picture Frame Matting Replacement: paso 4, imagen 1 de 1
    • Carefully remove the picture and old matting from the frame.
    • You can leave the glass in the frame.
  5. Picture Frame Matting Replacement: paso 5, imagen 1 de 1
    • Place the new matting into the frame and directly onto the glass.
    • Be careful while working around the glass to avoid self-injury or damaging the item.
  6. Picture Frame Matting Replacement: paso 6, imagen 1 de 2 Picture Frame Matting Replacement: paso 6, imagen 2 de 2
    • Position the picture properly and place it on the new matting.
    • Make sure there are no gaps between the edge of the picture and the matting.
    • Carefully place a couple of small pieces of clear tape on the picture and the new matting to hold it in place.
  7. Picture Frame Matting Replacement: paso 7, imagen 1 de 1
    • Place the backing on top of the matting in the frame.
  8. Picture Frame Matting Replacement: paso 8, imagen 1 de 2 Picture Frame Matting Replacement: paso 8, imagen 2 de 2
    • Rotate the backing clips under the frame to secure it.
Linea de Meta
Leah
Miembro Desde 01/20/23
160 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 28
Todo El Tiempo: 499
