Introducción
The motherboard is the key component behind this little speaker. If you're experiencing issues that have persisted through other troubleshooting guides, it may be time to replace the motherboard. The motherboard is a delicate piece of equipment, so work slowly and carefully to avoid damaging the speaker.
Qué necesitas
Remove the plastic cover in front of the battery slot.
Unscrew all the 8.5mm screws that hold the cover to the slot.
Separate the battery from the back panel as shown in photograph 3.
From the back of the motherboard, unscrew the three phillips head screws holding the motherboard in place.
3 personas más completaron esta guía.
