Saltar al contenido principal
Photive Rain Motherboard Replacement
Qué necesitas
  1. Photive Rain Motherboard Replacement, Back Panel: paso 1, imagen 1 de 1
    • Turn the speaker off before disassembling.
    • Remove the suction cup from its groove by twisting and turning it.
  2. Photive Rain Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
    • Remove back panel
  3. Photive Rain Motherboard Replacement, Battery: paso 3, imagen 1 de 2 Photive Rain Motherboard Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the plastic cover in front of the battery slot.
    • Unscrew all the 8.5mm screws that hold the cover to the slot.
    • Separate the battery from the back panel as shown in photograph 3.
    • Caution: manipulation of the device while the battery is still connected to the motherboard may result in electric shock.
  4. Photive Rain Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the battery from the motherboard.
    • Use a soldering pen to remove the solder connecting the battery wires to the motherboard.
    • Click here to access the iFixit Soldering Guide. This will provide a safe and instructive manual on the usage of soldering pens.
  5. Photive Rain Motherboard Replacement, Speaker: paso 5, imagen 1 de 1
    • Carefully remove the front panel from the device.
  6. Photive Rain Motherboard Replacement: paso 6, imagen 1 de 1
    • Detach the connector clips from the motherboard using the iFixit Opening Tool.
    • Some force may be necessary to remove the plastic clips.
  7. Photive Rain Motherboard Replacement: paso 7, imagen 1 de 2 Photive Rain Motherboard Replacement: paso 7, imagen 2 de 2
    • After the speaker is detached, remove the two 8.5mm screws that hold the speaker to the front panel with a Phillips #1 screwdriver.
  8. Photive Rain Motherboard Replacement, Motherboard: paso 8, imagen 1 de 1
    • From the back of the motherboard, unscrew the three phillips head screws holding the motherboard in place.
  9. Photive Rain Motherboard Replacement: paso 9, imagen 1 de 1
    • Pull the rubber away from the edge of the motherboard.
  10. Photive Rain Motherboard Replacement: paso 10, imagen 1 de 2 Photive Rain Motherboard Replacement: paso 10, imagen 2 de 2
    • Use the plastic opening tool to remove motherboard from device.
    • The second photograph displays a properly removed motherboard.
Conclusión
3 personas más completaron esta guía.
abcdef ghijk
Miembro Desde 02/15/16
723 Reputación
4 Guías creadas
Equipo
IUPUI, Team 1-4, Harley Spring 2016 Miembro de IUPUI, Team 1-4, Harley Spring 2016
IUPUI-HARLEY-S16S1G4
Miembros de 3
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 16
Todo El Tiempo: 328
