Saltar al contenido principal
Photive Hydra Battery Replacement
Qué necesitas
  1. Photive Hydra Battery Replacement, Face Plate and Back Plate: paso 1, imagen 1 de 1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra Battery Replacement: paso 2, imagen 1 de 2 Photive Hydra Battery Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra Battery Replacement: paso 3, imagen 1 de 1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra Battery Replacement: paso 4, imagen 1 de 1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra Battery Replacement: paso 5, imagen 1 de 2 Photive Hydra Battery Replacement: paso 5, imagen 2 de 2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra Battery Replacement, Battery (Prerequisite): paso 6, imagen 1 de 2 Photive Hydra Battery Replacement, Battery (Prerequisite): paso 6, imagen 2 de 2
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
  7. Photive Hydra Battery Replacement: paso 7, imagen 1 de 1
    • Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
Conclusión
Una persona más ha completado esta guía.
Matthew Knight
Miembro Desde 02/09/16
246 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 11-3, Cheng Spring 2016 Miembro de USF Tampa, Team 11-3, Cheng Spring 2016
USFT-CHENG-S16S11G3
5 Miembros
6 Guías creadas
Un comentario
Great instructions, I replaced the battery and it works fine.
THANKS!
Terry - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 491
