Saltar al contenido principal
Photive Hydra Speaker Replacement
Qué necesitas
  1. Photive Hydra  Speaker  Replacement, Face Plate and Back Plate: paso 1, imagen 1 de 1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra  Speaker  Replacement: paso 2, imagen 1 de 2 Photive Hydra  Speaker  Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra  Speaker  Replacement: paso 3, imagen 1 de 1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra  Speaker  Replacement: paso 4, imagen 1 de 1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra  Speaker  Replacement: paso 5, imagen 1 de 2 Photive Hydra  Speaker  Replacement: paso 5, imagen 2 de 2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra  Speaker  Replacement, Speaker: paso 6, imagen 1 de 2 Photive Hydra  Speaker  Replacement, Speaker: paso 6, imagen 2 de 2
    • Identify the two Phillips (Length-5/16" Head-1/8") screws holding the speaker in place and remove them.
  7. Photive Hydra  Speaker  Replacement: paso 7, imagen 1 de 1
    • Remove the bracket holding the speaker in place.
  8. Photive Hydra  Speaker  Replacement: paso 8, imagen 1 de 1
    • Disconnect the wires that are connected from the speaker to the motherboard.
  9. Photive Hydra  Speaker  Replacement: paso 9, imagen 1 de 3 Photive Hydra  Speaker  Replacement: paso 9, imagen 2 de 3 Photive Hydra  Speaker  Replacement: paso 9, imagen 3 de 3
    • After all extra components are out of the way, you will need to remove the adhesive holding the speaker using either a heating gun or the iOpener kit (both can be purchased under the Parts and Tools Store section of the menu bar). Once that is completed, replace the broken speaker with the new, functional speaker.
  10. Photive Hydra  Speaker  Replacement: paso 10, imagen 1 de 2 Photive Hydra  Speaker  Replacement: paso 10, imagen 2 de 2
    • Identify the four Phillips (Length-5/16", Head-1/8") screws holding the speaker housing (below the battery) and remove them.
  11. Photive Hydra  Speaker  Replacement: paso 11, imagen 1 de 1
    • Identify motherboard.
  12. Photive Hydra  Speaker  Replacement: paso 12, imagen 1 de 1
    • Disconnect highlighted electrical cords.
  13. Photive Hydra  Speaker  Replacement: paso 13, imagen 1 de 1
    • Disconnect second highlighted electrical cord.
  14. Photive Hydra  Speaker  Replacement: paso 14, imagen 1 de 1
    • Pull motherboard up and away in order to remove it.
  15. Photive Hydra  Speaker  Replacement: paso 15, imagen 1 de 1
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the speaker in place and remove them.
  16. Photive Hydra  Speaker  Replacement: paso 16, imagen 1 de 3 Photive Hydra  Speaker  Replacement: paso 16, imagen 2 de 3 Photive Hydra  Speaker  Replacement: paso 16, imagen 3 de 3
    • Upon removing the plastic bracket, you will need to remove the adhesive using either a heating gun or the iOpener kit (both can be purchased under the Parts and Tools Store section of the menu bar) that is holding the speaker in place. Once that is completed, replace the broken speaker with a new, functional speaker.
Conclusión
Andrew Chase
Miembro Desde 02/09/16
352 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 11-3, Cheng Spring 2016 Miembro de USF Tampa, Team 11-3, Cheng Spring 2016
USFT-CHENG-S16S11G3
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 766
