Saltar al contenido principal
Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement
Qué necesitas
  1. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: paso 1, imagen 1 de 3 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: paso 1, imagen 2 de 3 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: paso 1, imagen 3 de 3
    • Pry the bottom cap away from the toothbrush body.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: paso 2, imagen 1 de 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: paso 2, imagen 2 de 2
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: paso 3, imagen 1 de 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: paso 3, imagen 2 de 2
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: paso 4, imagen 1 de 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: paso 4, imagen 2 de 2
    • Locate the power button (solder locations circled in orange).
    • Locate the mode button (solder locations circled in red).
    • Both buttons are attached by four soldered pins each.
  5. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: paso 5, imagen 1 de 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: paso 5, imagen 2 de 2
    • Heat the soldering iron.
    • Soldering can cause burns and fires. Always solder in a well-ventilated area.
    • To test if the soldering iron is ready, place on the solder and if the solder melts easily and quickly, your soldering iron is ready.
    • Use the soldering iron to desolder all of the connections.
  6. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: paso 6, imagen 1 de 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: paso 6, imagen 2 de 2
    • Use tweezers to remove the buttons from the board.
    • Place new button onto board and repeat previous steps in reverse to reassemble.
Conclusión
Liam Casto
Miembro Desde 04/01/24
354 Reputación
3 Guías creadas
Equipo
IUPUI, Team 1-4, Harley Spring 2024 Miembro de IUPUI, Team 1-4, Harley Spring 2024
IUPUI-HARLEY-S24S1G4
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 209
