Saltar al contenido principal
Philips Sonicare ProtectiveClean 6500 Battery Replacement
Qué necesitas
  1. Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: paso 1, imagen 1 de 3 Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: paso 1, imagen 2 de 3 Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: paso 1, imagen 3 de 3
    • Pry the bottom cap away from the toothbrush body.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Battery Replacement: paso 2, imagen 1 de 2 Philips Sonicare ProtectiveClean 6500 Battery Replacement: paso 2, imagen 2 de 2
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Battery Replacement: paso 3, imagen 1 de 2 Philips Sonicare ProtectiveClean 6500 Battery Replacement: paso 3, imagen 2 de 2
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Use an opening tool to gently pry up the battery.
    • Remove the battery.
Conclusión
Liam Casto
Miembro Desde 04/01/24
354 Reputación
3 Guías creadas
Equipo
IUPUI, Team 1-4, Harley Spring 2024 Miembro de IUPUI, Team 1-4, Harley Spring 2024
IUPUI-HARLEY-S24S1G4
Miembros de 3
3 Guías creadas
2 comentarios
Hello, thanks for your tutorial!
Is there others Sonicare models like this one where you don't have to desold the battery ?
Julien CHAZAL - Contestar
It doesn’t appear you have to desolder the battery with this model. I think the diamond clean does require desoldering though.
Jacob Poole -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 21
Todo El Tiempo: 258
